JLT Oil Separator
Started by WhitePlatinumSHO, April 30, 2014, 09:36:13 PM
WhitePlatinumSHO
Just got an oil separator from JLT. Going to install it on the weekend, but if it's anything like their Mustang products....it will work awesome. Anyone have one already? Curious how much oil it actually collects over a set period of time....
2016 Platinum White SHO
- Unleashed Tune & 3 Bar MAP
2010 Red Candy SHO - Gone but not forgotten
1997 Cobra Coupe - 659rwhp / 609rwtq
WhitePlatinumSHO
Thanks. Don't get me started on UPR though... :0
Quote from: 4DRHTRD on April 30, 2014, 09:52:12 PM
Take a read - not the same catch can but close from my understanding:
http://www.f150forum.com/f70/upr-vs-rx-catch-can-effectiveness-test-254381/
Wonder how long it will be before there's any results?... looked like it would take a while.
nitrous_mike
Quote from: RedCandySHO on April 30, 2014, 09:54:06 PM
LOL you sound like me...... When I was running in NMRA they offered to give me a front end kit and I just laughed why would I take out a PA racing front end for  something that is well you know...
I wonder how well an electric vacuum scavenger would work on these cars ?
JimiJak
Quote from: RedCandySHO on April 30, 2014, 09:36:13 PM
Can't wait for pics and results!
...hey, that reminds me; didn't SHOboat install some Moroso's a while back. Oh yeah...here it is. I wonder what ever happened with that??
2014 XSport Black Betty Build
WhitePlatinumSHO
JLT Oil Separator is installed.....will check it in a few weeks to see how much it catches. Simple install....comes with everything required to simply connect (Factory quick connectors etc.) it etc.
Kewl!  More firsthand data :thumb:
Tuner Boost
RX challenge:
You can do the same challenge, but bear in mind, the UPR is more effective than the JLT, so expect most to get pulled right past and still be ingested.
Anyone with any can that wants to do the test, you will never look at catchcans the same way again.
Up for testing the JLT with the RX behind it to show how much gets past it?  Any can that allows the oil to pass right through may give you a "placebo" effect thinking you are addressing the issue, but until to personally test and see you won't believe how much is pulled right past 99% of the cans on the market no matter what the brand, or what the manufacturer claims.
Dxlnt1
So is a catch can really necessary? Or has Ford designed these engines to allow for that blow by?
Looks like the RX catch can does collect blowby.  Blowby does tend to accumulate and gunk up the engine systems over time.  Supposed to be burnt up during the combustion process, but it does have to travel to get to the combustion chamber.  Guess what happens along the way?  That's right, unwanted deposits!!!  Not optimal for engine efficiency, and certainly not for cleanliness.
explorergotoluvit
its real important any performance turbo engines subys bmw vw now are stuff its just good to have
2013 explorer sport
LMS tuner stat 160 3 bar magna flow v8 91 map
k&n H&R spring
retrofit FXR bi-xenon projectors done by lightwerkz
all lights replaced with leds from daytimebrightlites
Dxlnt1
Quote from: SHOdded on May 13, 2014, 11:23:17 PM
So engine cleaners such as Techron wouldnt be sufficient to clean those deposits? Just asking
Problem is you have a GDI engine, and a TC one at that.  So any cleaner you add to the fuel only gets to the injectors and the combustion chamber.  You miss cleaning the intake tract, the intake valves, the turbo system, you get the picture.
