Started by EcoPowerParts, January 14, 2013, 08:56:36 AM
shoNoff
I already see this ending badly. My wife standing in the driveway giving me that look. Yes all us married guys know the look. As the edge is on a flatbed with the rods hanging out of it lol.
2013 SHO PP 12.51 @ 110.07 AJP tuned sold
2016 edge sport 13.92 @ 99.4 mph. slow and stock baby mobile
802SHO
Quote from: shoNoff on August 13, 2019, 04:06:42 PM
She knew what she was getting into when she signed on the dotted line
shoNoff
Quote from: 802SHO on August 13, 2019, 04:13:46 PM
She's a trooper for sure. Hell she was bringing me map sensors at 3am in the New England dragway parking lot lmao
802SHO
Gofspar
#6859
Got a misfire on Cylinder 3 today after letting off WOT, my new longblock has just about 1500 miles on it same with the plugs.
gonna run a bottle of Amsoil PI through the tank and bought some MSD coils, still running the 9 year old OEM ones.
AJPTurbo E30 3bar rev4, SP-534 .28, MSD coils, reische 170 tstat, ARH Catless DP, resonator delete, magnaflow mufflers, airraid CAI, H&R sport springs, UPR Catchcan /w CCS, SSM "Street" RMM
Quote from: Gofspar on August 14, 2019, 04:58:40 PM
Which plugs and what code ? Z
Gofspar
#6861
Quote from: ZSHO on August 14, 2019, 05:37:02 PM
P0303, SP-534 gapped to .028
It happened, blinked and went away.
cleared it and ripped it home and didn't come back.
happened after decel(maybe, wasn't really paying attention to the dash) from a pull from like 20-130 as soon as I lifted, might be an injector.
TopherSho
#6862
This is similar to my current ongoing issue.
Also on a remaned long block.
What injectors are in there.. curious if there the same as mine.
Best 0-60 public road 4.35s
Gofspar
Quote from: TopherSho on August 14, 2019, 10:45:57 PM
not sure honestly lol, haven't taken a look.
is yours misfiring consistently, or just every once in awhile?
TopherSho
mine is reproducible at will.
drop to manual mode go into 2nd gear.  drive at 3200 rpm .. in 30 seconds i feel it misfiring and the cel pops.  stop the car,  cel stops after the cylinder dries out in like 15 seconds.
im 99% sure it is the plug gap.. the frustrating thing is BEFORE the remanned block these plugs were fine. So i think the issue is the injectors somehow have a different spray pattern or flow and wet the plug in one cylinder.
Gofspar
#6865
Quote from: TopherSho on August 15, 2019, 01:37:40 AM
have you tried techron or amsoil PI or anything similar, it wont fix a borked injector but can change the spray pattern if theres something blocking it
I'll try 2nd gear at 3200rpm tomorrow morning and see what happens.
in before same issue lol, also your reman didn't come with new plugs?
TopherSho
I did switch oils with no effect.  I don't think the injector has a blockage,  but i do think the injector is wetting the plug under low load, sustained high rpms in the 3000's.  I don't think the injector is bad either as the AFR and STFT look great .. it is just flowing different somehow.
i have not tried nay higher rpms .. i seemed to dangerous on my block with only 3500 miles on it.
Gofspar
Quote from: TopherSho on August 15, 2019, 01:48:45 AM
I ripped mine after like 250 miles lol, stuck er on the dyno.
brad said stick amsoil in it and just send it, so thats what I did.
802SHO
Filled up my 5lb bottle of Nitrous yesterday.  Got the go ahead from Brad this am to datalog a 15 shot on my current 19 psi tune.  From the wise words of SBS, since I'm already spraying " a metric $#it ton" of methonal, the meth should handle that 15 shot no problem.  This will probably be my engines new favorite snack
Datalogs this weekend and performance test for comparison pre and post Zex 15 shot of nitrous.
P.S.  also detailing the car but everyone should be doing that lol
SM105K
Hahah Brad did mention that in his email to me....
I guess I am a bad influence, GOOD.
