Decided to make a new thread for this specifically to take suggestions/comments/and show results concerning the exhaust.
Exhaust installed, MDesign Race Spec Prototype 1. Uses 2.5" piping which split to a single 3" piping then back to dual 2.5" at the rear, all stainless free-flow mufflers.
Pros: Increased power/quicker spool, better gas mileage, and now gurgles when you blip the throttle, sounds beautiful downshifting
Cons: Drone in 1800-2500RPM
Performance gains are confirmed via SCT X4 tuner. Under cruising and slight blipping of the throttle (1000-2000 RPM range) most of the time I am at -10 vacuum up to 0psi pre exhaust, post exhaust I now hit 2psi doing the same thing. Also I spin the tires effortlessly now, whether it's from a dig or roll on 1-2 and 2-3 shifts. While there is no rasp whatsoever and no drone in other RPM, the drone that is only noticeable in the 1800-2500 RPM range is a bit much to my liking therefore I'm willing to sacrifice some performance for sound reduction.
As of now I am contemplating using an oval shaped resonator up front which should eliminate drone considering the system is completely free-flowing, though am not sure if I want to stick with the original design (JimiJack's dual inlet/outlet resonator) or a wider and larger volume single in/out.
Here is a quick video, rattling is the phone in it's make shift temporary cup holder not the exhaust!
