Hesitation and high KR Cold weather issues?
Started by ShoBoat, April 05, 2015, 12:19:47 PM
With SCT, I can turn 6 of the available data streams into gauges then I can pull the curser across time/rpm and see what is happening at every data point, if that makes any sense.
ShoBoat
Quote from: FoMoCoSHO on April 25, 2015, 11:10:43 AM
I can do something similar in Forscan, there is a button at the bottom of the screen that will show me the values in sequence. No gauges though.
2012 Pearl White CTS-V Stock
Quote from: ShoBoat on April 25, 2015, 11:15:45 AM
Was your LPFP replaced on the recall?
ShoBoat
Quote from: FoMoCoSHO on April 25, 2015, 11:18:09 AM
Yes it was replaced.
Have you logged it to make sure it isn't dropping out?
ShoBoat
Yes the logs also show LP side of the fuel system on the other page. It doesn't look to me like its dropping out much.
From the graphs, I'm only seeing the problem when you STAY on the throttle.  On the 55mph 2nd run w/ V7 is where the problem manifested itself.
ShoBoat
Quote from: SHOdded on April 25, 2015, 12:55:51 PM
Agreed, however the stock tune modulates the throttle plate even though it's at WOT on the AP sensor. The tune file send the command to the TP and its wide open through the whole pull. This is the only difference I can see from the logs. And the drop in HPFP.
Quote from: ShoBoat on April 25, 2015, 01:26:55 PM
Agree x3^^^
Bettin' on the fuel control module... If the LPFP is working properly...
AJP turbo
Are you suspecting there is a problem with fuel delivery because the pressure dropping?
SCT Dealer/Custom Calibrator
Specializing in 3.5 Ecoboost
Former:2014 PP SHO
405whp/520tq
Dyno
Tuning in progress
ShoBoat
I am being drawn back to the winter fuel (again). I have to do some more research on its effects on AFR and lambda.
AJP turbo
Quote from: ShoBoat on April 25, 2015, 03:39:25 PM
What do u mean?
The O2's will take care of afr and lambda via stft ....and u will never maintain commanded fuel pressure of 2000 or so when at wot with a 3 bar tune...u are pushing the fuel system to the max more specifically the high pressure pump...I think I said this before but I'm commanding 2200 and I'm lucky to see 1000 ..when I'm at 18 psi below 3000 rpm I'm lower than 1000 psi rail pressure
Former:2014 PP SHO
405whp/520tq
Dyno
Tuning in progress
91hybrid
Quote from: ajpturbo on April 25, 2015, 03:47:29 PM
What do u mean?
Even with meth this is still true, however lamba's are kept in check but the additional fuel is using 100% meth that is.
2014 SHO -PP, Unleashed Tuned, 3bar, Devils Own 100% meth, PPE catted down pipes, 3rd cat delete, Magnaflow 2.5" exhaust, 170 deg, NGK 7's plugs, hot pipes - White Platinum 401a
418 whp - 513 wlb/ft
non meth 13.11@103.6 (knock limited)
Meth pass 11.991@114.28
I see 2100 at WOT all the time. Actually closer to 2200 most the time. Hmmm?
Rich
