Rear level extremely low
Started by Capri83RS, April 19, 2016, 08:32:36 AM
Capri83RS
I've noticed that the rear level of sound is exceptionally low compared to the front.  In order to get "equalized" sound, I have to set the F/R fader to about 2/3rds of the way to the rear.  This is affecting the rear doors and rear deck speakers.
Any idea what would cause something like that?
1984 Capri RS
1991 F150 4x4
2013 Mustang GT Track Package w/ Recaro's
2014 Taurus SHO
Did you check and make sure the surround mode is not on?
Capri83RS
Quote from: glock-coma on April 20, 2016, 06:36:43 AM
I did, and there's a noticeable difference in whether the voices come out of the doors vs the single rear center channel.  But it didn't change the sound level, which is noticeably lower compared to the fronts.
1984 Capri RS
1991 F150 4x4
2014 Taurus SHO
Rear deck speakers are subs and a center channel only. If I remember correctly the center has 68uf cap on the + lead which would be around 350hz crossover point.
So it's just used as rear "fill"
Rear doors are full range. Crossed around 80hz. Not sure what could be causing the low output
Does the audio mute when the car is in reverse gear/backing up?
Capri83RS
Yes, all audio mutes with the car in reverse and the sensors going off.  After a few days, it seemed to have resolved itself.  I played with the fade front/rear and adjusted it out, and now I can center it in the image, and it sounds normal.
1984 Capri RS
1991 F150 4x4
2014 Taurus SHO
