FORScan?
Started by Gjkrisa, October 28, 2016, 10:54:00 PM
Gjkrisa
Also before you change anything just make a backup of all the modules you have to do it one module at a time. It saved me when I didn't fully understand what I changed
MiWiAu
Quote from: Gjkrisa on January 15, 2017, 10:06:31 AM
Thanks for the tip on backups. Pretty sure I didn't get a clone, but I will get the app to verify.
2013 XSport
Not had a fallout yet.  3+ years in service.  But then again, y'all's rides have more sophisticated systems than mine.
MiWiAu
Quote from: Gjkrisa on January 15, 2017, 10:03:32 AM
I have not.
get obd link app to verify you didn't get a clone
Quote from: SHOdded on January 15, 2017, 10:50:50 AM
I'm running Windows 10, and the connection goes between "connected" and "paired". Apparently this is normal with Windows if a signal isn't being actively transmitted. Registered the device with the OBDwiz application, and everything seems kosher.
When I execute service procedure to program a module, it seems to stay connected, but if I clear a DTC, it will work once, then I get a "No ELM found. Please check connection and try again". If I close FORScan and reconnect it works again. I turned off a power save feature in my device manager for Bluetooth, but this didnt seem to make much of a difference. Guess I will just proceed with caution.
2013 XSport
Gjkrisa
interesting i have windows 10 also but i have a asus bluetooth adaptor i had to buy and just used windows bluetooth device control to add the obd device .
ive never cleared a dtc with the laptop though.
let me know if you make a change to the modules and still have it disconnect just something id like to know.
if so id try to just register using windows Bluetooth.
I have only used Forscan Lite on Android to clear codes (with ignition in ON but with engine off), and never had an issue with pairing.  Sounds more of device issue on the Windows side.  I know when I tried to use Forscan on Windows 7, it was a bit picky with its' Bluetooth adapters/connections.
MiWiAu
Quote from: SHOdded on January 15, 2017, 03:57:25 PM
Yeah, I'm leaning towards Windows goofiness. I did make a change to the BCM to turn off the double horn honk, and it worked with no issue.
I'll keep you guys posted if I have any other problems. Thanks! :)
2013 XSport
Izzybird
It may already be here somewhere, but here is what I did to disable the double honk on '15 SHO.
726-16-01 0211 57 as built
726-16-01 0201 47
Wife's '15 SHO non PP
Gjkrisa
Quote from: Izzybird on April 23, 2017, 02:42:06 PM
726-16-01 0201 47
Thank you I will try this!
Gjkrisa
726-16-01 0201 47
It worked!
How did you figure that out?
Half-Fast
Anyone using a wifi adapter with Forscan?  I want to go that route because the bluetooth isn't compatible with the iPhone app (so they say).
2014 SHO PP Deep Impact Blue.  All stock...
Izzybird
#41
Quote from: Gjkrisa on April 23, 2017, 04:17:46 PM
It worked!
[/quote]I noticed on the exploder forum that the third digit number needed to be changed to a zero and just gave it a try. How long do I have to go through the verification questions before I can post? It's already getting old.
Quote from: Izzybird on April 23, 2017, 05:44:21 PM
It worked!
[/quote]The security verification feature should go away after the 5th post.  Z
Izzybird
Quote from: ZSHO on April 23, 2017, 05:51:37 PM
It worked!
[/quote]
Thank you
Izzybird
I wanted to try the AWD Gauge but that line doesn't offer to write and I did not want to try "write all", I'm still green to all this. I just got the adapter Friday.
