Vapor Canister Purge Valve!!
Started by ZSHO, December 06, 2016, 04:33:03 PM
2010Limited
Here is mine -
I thing 8G1Z-9F945-A is the canister VENT solenoid, no?  Usually the base number for the PURGE solenoid is 9G271, but it may be different ...
AA5Z-9G271-C
Shows as discontinued, is listed as a hose assembly
[img height=300 Width=300]https://www.ecoboostperformanceforum.com/index.php?action=dlattach;topic=7133.0;attach=21372;image[/img]
I think you might have to use ONE of the existing stock Hose connectors in order to fit! Z
Pull off the purge valve and let's see what Ford stamped on that part.  Might be helpful, might not ...  With any luck we can find that valve separately.
2010Limited
Quote from: ZSHO on August 22, 2019, 08:13:54 AM
I think I read somewhere in this thread that one of the hoses was wrong and the poster had to re-use one hose. On rockauto it didn't appear it came with either hose.
Rockauto has the wrong part listed for the EB, that is a valve used on the naturally aspirated 3.5
2010Limited
The dealer does not sell just the vent valve.
My cost with my account is $127!
Tasha sells it for $87
2010Limited
Is there a way to test that valve?
Normally if you pull a vacuum on it for 5 min or more and it does not hold, the valve is faulty.
The basic test goes like this, skip to 6:30 or so if not watching the whole video
https://youtu.be/VLg1PEpFfsU
