E30 testing at Rock Falls
Started by hawkeye93, July 15, 2017, 03:48:24 PM
hawkeye93
First 3 passes were BCB E30 tune with meth, last 2 passes were AJP E30 tune without meth.  The first 3 runs all beat my previous PB.
Edit: Added datalogs
2015 Ford Taurus SHO PP 12.219@112.84
PPE catless DP, Gearhead IC, SP-534, Reische 170, 3 bar, hybrid meth system, tunes from Unleashed, Livernois, Brew City Boost & AJP
1965 Ford Mustang Convertible 289 4V/T5Z/3.55
1955 Ford Fairlane Club Sedan 272 4V/Fordomatic
StealBlueSho
Good times! Surprised at the half second difference?! You have datalogs of the run? Or any prerun BCB datalogs?
hawkeye93
The AJP tune is an early revision, I expect there's some room for improvement there.  I did get logs on all but the 4th run; I forgot to press record on that one.  I also got some GoPro videos, I'll link after I get them posted to YouTube.  The battery died on my Hero 5 before the last run.
StealBlueSho
Quote from: hawkeye93 on July 15, 2017, 04:25:22 PM
You gonna post logs?
hawkeye93
Quote from: StealBlueSho on July 15, 2017, 05:34:39 PM
I added them to the first post.
StealBlueSho
my bad... tapatalk didn't pick that up. Thanks!
StealBlueSho
Wow... logs look good! interestingly enough Brad has a lot less boost and about 6 degrees less spark on his E30 without meth tune and its not THAT far behind the BCB... he is aggressive on his IAT compensations to help protect the motor so towards the end of the run the spark was a bit lower... I would be interested to see what you put down time wise once brad gets a few revisions in with the meth...
Again, nice times!
Colorado-SHOBro
Quote from: StealBlueSho on July 15, 2017, 06:10:48 PM
Again, nice times!
Not to mention AJP's tune is using throttle to control the boost spike and torque reduction is not removed or reduced at all like in BCB's tune. That combined with the absence of meth and rising IAT throughout the run would easily justify a half second difference. . in fact i'm surprised there's not a bigger spread between the 2 tunes.
Nice runs and thanks for posting the slips and datalogs hawkeye! can't wait to see some vids
12.8@108 @ 6,000ft DA.
StealBlueSho
Curious... you have tunes from LMS, Unleashed, Brad, and BCB... curious... what are your times with the LMS tune? Unleashed tune?
hawkeye93
Quote from: StealBlueSho on July 15, 2017, 06:33:44 PM
From a hot June day:
http://www.ecoboostperformanceforum.com/index.php/topic,7911.0.html
StealBlueSho
Quote from: hawkeye93 on July 15, 2017, 07:18:15 PM
Have you ever datalogged your LMS meth tune? And I am assuming your running a non-dynoed tuned LMS meth tune...
hawkeye93
#11
Quote from: StealBlueSho on July 15, 2017, 09:13:25 PM
Here are the LMS logs from my June track session.  And you are correct, my car is not dyno-tuned.  I will make some dyno runs soon, but more to satisfy my curiosity, not for tuning.
hawkeye93
#12
Brucelinc
Great Job, Hawkeye!  Thanks for sharing timeslips, logs and videos!
