I picked up an awesome catch can from ZSHO (thanks again man, you rock!), and now I'm getting into hooking the thing up. I bought the kit incomplete to save a few bucks, and I've run into a couple issues. The kits on the RX website have what look like barb fittings on the top of the can. The one I bought has a fitting type that I am not familiar with. Call me dumb, but I've never used this type of connector before.
Anyone know what size lines these require? I tried test fitting a section of clear 3/8" inside 1/2" outside diameter hose and that seems to fit... But any 3/8" fuel tubing I find has too thick an outside diameter to fit in the section of these suckers that I removed in the second pic. I'm tempted to leave that piece off and jam the lines onto the threaded section and put a clamp on it. Is that too awful?
Second issue. What size hose connects to the PCV fittings on the valve cover and intake manifold? I've seen some sources say 1/2" and some say 5/8". I can't cut the hose off of my PCV fittings to test fit because I need to keep driving the car around town to buy the hoses and fittings, lol. Once I have all the pieces I need, I can get the install done, all in one shot. Any help would be greatly appreciated.
