Blue smoke after hard acceleration - Will a catch can help?
Started by Gray Brick, December 04, 2017, 12:12:58 PM
Gray Brick
I had one of my air filters come off the turbo inlet tube.  This created less vacuum for the PCV system during boost so I had more blowby.
Unfortunately I put a catch can on at the same time so I don't know if it was one or the other.
I am sure they both helped the situation.
2013 Ecoboost Ford Flex
