I'm assuming the heater core draws coolant after it goes through the turbos and that's why you get heat in only a couple of minutes on our Ecoboosts? Over the past week I've noticed that I get heat if the engine is revving above about 1200 or so RPM but then if I'm stopped at a light it blows cold while idling. I take off from the light and I again have warm air blowing after 2-3 seconds. I've put it in neutral at the light and revved it up slightly and get heat too. It only does this when the engine isn't fully warmed up and it seems like it acts normal after (I assume) the thermostat starts opening up. Is this normal? If so, what is causing this? Coolant level is fine. Could add 8-10 ounces is all.
