- The Magic Boost Bus
- Full Member
- So Flexy
- Logged
Quote from: mattr66 on March 05, 2018, 11:36:54 PM
Quote from: Agentlongwood on February 01, 2018, 09:18:31 PM
Well if all those numbers prove accurate, and the price stays the same, I would most likely be buying one as well. Kind of mind blowing that the gains are so substantial just by switching to bar-and-plate, with the core going all the way to the end tanks. If that's the case, couldn't you buy a bar-and-plate core in the proper dimensions. Then get some end tanks from a junk yard and have them attached to the new core. Or is this way more complicated than I'm making it sound?
Factory end tanks are plastic
V1 of the intercooler use an aftermarket intercooler and just replaced the core with a higher flowing one with more surface area... V2 has newly designed end tanks to flow more air and have a flange like stock for ease of installation.
I'm waiting with baited breath for this to happen!!!
2014 Ford Flex Limited AWD EcoBoost - Full Amsoil Synthetic Fluids swap in engine and driveline, SCT X4 Tuner w/ multiple tunes for 93 + Meth, Dash-mount Tablet running Torque Pro Gauges w/ BT Wireless OBD Adapter, 170 T-stat, 3-Bar MAP sensor, Denso 1step Colder Spark Plugs, OBX Catless Downpipes, Magnaflow Downpipe-back 2.5" exhaust system, Magnaflow 2.5" X-Pipe, MDesign Carbon Direct Cold Air Intake (Latest Gen), UPR 3-way Catch Can System, Devil's Own Stage-2 3-Bar Methanol Injection System with custom Tank/Pump mount, EcoPowerParts Black powder-coated Charge Pipe kit, TIAL Q Race BOV in Ruby Red color-match, Power Stop Z23 Brake upgrade on all 4 corners with Drilled/Slotted Zinc Rotors and Carbon Fiber-infused Ceramic Pads with color-matched Ruby Red calipers, Moog upgraded Sway Bar Endlinks, lowered on Megan Racing EZ Street coilovers, SPC Rear Camber kit, Verde Axis V99 Bronze 20x9 wheels wrapped in 275/40 Nexens, Custom forged 4 1/2" spiked one-piece steel lugs, Kicker CompRT 12" Sub in custom spare tire-well box, Polk Audio Carbon C500.1 mono sub amp, All-Fit Front Lip Spoiler, 3D Carbon Rear Wing, Ruby Red vinyl wrapped interior trim, LED-lit "FLEX" Door Sills, Full LED Interior bulb swap, Red LED Accent lighting throughout, SpiderMax 3D Kagu black laser fit floor mats for all 3 rows, LED Puddle Light swap, Tinted LED Tails, Windows Tinted all around.
