![*](https://www.ecoboostperformanceforum.com/Themes/default/images/membericons/forum_2_junior_member_s.png)
- Jr. Member
- Ecobooster
- Logged
I used a holley blue kit for fuel and gutted bmw sending units and turned them into pickups to feed fuel to the holley pump and forward to a regulator and then to a old holley from an f100 mounted to a weiand intake I had bought a while back for $40. I used a 85gt distributor and a med 6al to run ignition. The trans is a c4 from a 66 mustang that I bought as a core and rebuilt. I made a linkage and installed a B&M ratchet shifter under the Bmw trim and a bracket for throttle cable. I through together some brackets for the accessories and ran a 3g alternator and a fox Ps pump with a mustang line and cut the rack end off and installed a swivel with the BMW fitting welded with nickel silver. I mounted a radiator from an old ranger due to hose location and space issues. Exhaust was 2 passenger side manifolds with drivers side turned backwards to clear steering shaft. Pipe went forward through bumper and turned back on passenger side and connected with Y pipe into factory exhaust. I made a template for trans mount out of aluminum bars to support driveline while I measured for driveline angle and driveshaft length. I had Oliver's drive shaft in Winston Salem make me a driveshaft with Bmw flange for diff and mustang trans.
2013 Limited F150 4x4, OEM turbos with CRP billet compressor upgrade, Meth injection, PCV deleted and VC's vented to a custom blow by tank in bumper, Corsa exhaust, Turbosmart BOV, AEM drop in filter, tuned on SCT (93 and E30 +METH), leveled on 305 NT420's, DD
2016 Mustang GT, premium, Performance Pack, 6 speed, Lund Tuned on HP tuners
1995 Mustang GT, 347, AFR heads, custom nitrous roller cam, EFI, NX wet plate 175shot, Astro T5, stock suspension, 275 radials
1979 F250, 1970 460BB, DOVE-C heads, 850 holley, solid roller, long tubes, 10" suspension lift, trac bars, 4 speed, 42x15x15 TSL's
1989 Honda Crx HF, H22A1 swap, custom 4-2-1 header and test pipe, cable trans conversion, driveshaft shop axles, NX wet single nozzle 175 shot, trac bars, stripped, 1800#'s
