- RotM Winner
- Elite Member
- Boosted
- Logged
I realigned my SHO a few days prior as well. It had been a couple years since aligning it, I did have a very slight pull to the right. I believe correcting the alignment was helpful as well as beneficial in general for obvious reasons.
Messing with my tire pressure was advised by two ppl and I'm not sure how much it helped but I would have to conclude it couldnt hurt. Usually my psi is at 40 all the way around. I dropped 10psi in each to help with traction.
Also my car was very cold for my first run. Which was forced due to the track opening late. 3 hours waiting to open, then about another 45 min to start test and tune. I never would have waited that long otherwise.
Weight reduction is no joke. I took my back seats out.....im curious what removing the passenger seat and perhaps purchasing a lightweight battery would do. I believe those batteries are less than 15 pounds.
Jordan is right, a combination of minor changes adds up. And its reasonable to assume it won't...while you're making the changes.
I took the backseat cushion out...it feels like 10 pounds maybe. The upper seats feel like maybeeeeee 60 pounds. My friend who came with me felt them and didnt think it would do anything. So I took on jokes the rest of the way...hey man take your gum wrappers out of your door that will slow you down. I knew that wouldn't do anything but just to play along..gum wrappers came out too!
The reults speak for themselves. I did the fluid changes just for peace of mind and bc it never ever hurts to replace them.
I would also have to say tuning is very critical. AJP has tuned my SHO to be lethal when hit the gas and purr like a kitten when I don't. Nothing has been left to chance tuning wise. We weren't one and done. We did 9 revisions. I've been to the track 4 seperate times and datalogging my runs for review. Revision 8 and 9 were created off that data. You can't hope to be fast you have to continuously test and make adjustments. Look at my mods I'm not doing anything crazy and I'm on 93 pump gas.
