Splash Cover Repair
Started by polskifacet, January 29, 2019, 12:31:20 PM
polskifacet
Hey Guys,
Some pictures of the fiberglass patches I made for the undercover. Unfortunately I just broke the repaired cover again last night. Try to avoid backing up over snow as the cover then acts like a big shovel and buckles.
donky4444
I just had to fix mine tonight due to snow. The back two connectors let go and it was dragging. I got it to a friends heated shop and up on ramps. I lost the passenger side rear connector so that got a big zip tie and the drivers side was jacked up but I got it fixed and reattached. Fingers crossed it holds now.
802SHO
I didn't know there was an undercover shield.  All I have is a splash guard.
802SHO
Quote from: 802SHO on January 30, 2019, 02:06:45 PM
Oh its in the rear
The under cover is the larger of the two shields located under the oil filter,so technically you will need to remove that in order to gain access to oil filter & plug, 02 sensor..
The lower Deflector is in the front lower bumber area pictured below. Z
802SHO
Quote from: ZSHO on January 30, 2019, 02:28:53 PM
Oh its in the rear
Is this on all years?  I bought my car used and its never had that cover hiding the oil filter,plug + O2 sensor.  Explains why this was puzzling to me lol
Sbouvia
Whoa I am supposed to remove something to change the oil filter/drain the oil? We bought our 2013 brand new in November of 2012 and I do not think I have that cover. I can just grab my oil filter and take it off.
~Scott
2013 SHO non-pp. Powerstop Top Cop kit rotors and stock Akebono Ceramic Pads, 3bar map sensor, 93 octane 3bar AJPTurbo tuned, but not dialed in.
2002 Jeep Wrangler TJ (Jane) w/ 2.5" lift, Banks torque tubes, monster exhaust and intake.
1991 F Super Duty 2.5 ton dump truck w/ 7.3IDI
Thats a bit odd because Both my 13 SHO' S Had the cover underneath!
Sometimes the dealer forgets to install it after having it serviced and has happened too me on a couple occasions..
The XSPORT on the other hand Does NOT have a cover IIRC. Z
The best method is to open your hood and take a peep between the front engine and Fans,looking straight down to see if there is a cover or bear floor.
I would also avoid Auto car washes as they can pull it off to non existence.  Z
802SHO
Quote from: ZSHO on January 31, 2019, 06:47:46 AM
I would also avoid Auto car washes as they can pull it to non existence.  Z
Yes I have the splash guard that attaches that covers that area (aux cooler, Alky pump and fog lights) but the bigger cover...never had.
If it wasn't for this post I never would have known I was supposed to have one.  Still learning about my SHO😏
Quote from: 802SHO on January 31, 2019, 06:52:59 AM
That cover is made for aerodynamics and acts as a protective barrier against the elements while ultimately slowing you down @ the track. Z   ;D
