AJP Turbo:
I datalogged some more, with the PIDs you recommended at SCTFlash (Torque Source). Instead of 0 or numbers, I see text like Driver Demand, Trans Trunc, Trans Shift, TQ Based Decel, TipOut Limit, TipIn Limit
Any ideas on what these mean? I think Trans Trunc refers to the torque limiters in the Transmission Torque Management tables.
I also didn't understand your comment about fuel pressure, "if it gets under 1200 psi you are out of fuel". I was datalogging the high pressure fuel data, and my Actual max pressure was 2530 psi, Desired max pressure was 2150 psi, and the SAE Fuel Pressure reading was 2202 psi.
The highest TIP Actual I saw was 60 inHg, same with desired - makes a bit of sense since it is a 2-bar MAP and I'm still stock.
Highest massflow reading was about 40 lb/min.
Running 87 octane, the most spark retard was 7 degrees in 2 cells, most of the other cells averaged between 1-3 if it pulled any spark.
