MDesign Intake review-bigmoneycloser
Started by bigmoneycloser, November 25, 2014, 08:01:57 PM
I do like the looks of the setup there though :)
MDesign Performance
Quote from: SHOdded on January 22, 2015, 05:33:08 PM
Thank you! I try my best to make everything look good, even the prototypes ;)
Nothing beats the class and sophistication of genuine carbon fiber though! :chay:
sales@mdesignperformance.com
www.mdesignperformance.com
91hybrid
Quote from: 91hybrid on January 21, 2015, 04:47:57 PM
Does it really matter if it is +2 degrees above ambient?  With the obvious sensor error exhibited in this thread it's probably safe to say that the intake is getting as close to ambient temp air as possible (below is impossible) right now. Good job MDesign on that specific kpi (key performance indicator).
John
Why a few degrees doesn't really matter:
http://www.ecoboostperformanceforum.com/index.php/topic,4262.msg66240/topicseen.html#new
2014 SHO -PP, Unleashed Tuned, 3bar, Devils Own 100% meth, PPE catted down pipes, 3rd cat delete, Magnaflow 2.5" exhaust, 170 deg, NGK 7's plugs, hot pipes - White Platinum 401a
418 whp - 513 wlb/ft
non meth 13.11@103.6 (knock limited)
Meth pass 11.991@114.28
Boost4Life
#138
EDITED for argumentative nature of posting carried over from another forum/location.
avidmotion
Ok.....I have read 10 pages of heated arguments over this intake. I am on the fence, either a sealed insulted Windstorm/Air raid or this MD cai. Icare only of reliable performance need no extra noises don't want to loose anything. What happened to the two end all dyno runs with the MD,? Do I assume they not go well so no mention of results? Anymore info, updates?
Here is a comparison between three intakes,hope this helps any. Z
http://www.ecoboostperformanceforum.com/index.php/topic,4705.0.html
