Cleaning the pores of the Multi-Contour leather seats
Started by setaonivek, December 23, 2015, 07:52:23 PM
setaonivek
General detailing question .. we all love to keep our cars clean.  I have a serious neurosis when it comes to my SHO .. so, what do you use to clean your seats?  Leather conditioners?  how do you gets the pores of the leather clean? Do you use a  paperclip type tool?
I use Meguires products but haven't touched the leather on this one yet.  I am thinking of using a higher quality product to really bring the leather to life .. get that buttery smooth feeling.. anyway .. any suggestions would be greatly appreciated
'15 SHO, PP, WPM
donky4444
I use Adams leather conditioner on the leather parts. For the suede inserts I just vacuum them and if they get dirty I use white vinegar on a rag to clean them.
J-Will
I use Adams too, with a soft bristle brush
3-bar
SP-542 plugs w/ GH gap
I personally use two bottles of Sonax which are mainly for leather and Alacantara suede,overall great product.  Z       http://www.amazon.com/Sonax-206141-Upholstery-Alcantara-Cleaner/dp/B00BBWJ16U/ref=sr_1_4?s=automotive&ie=UTF8&qid=1450922185&sr=1-4&keywords=sonax+leather+care            http://www.amazon.com/Sonax-289300-755-Leather-Foam-13-02/dp/B003USYN6Q/ref=sr_1_1?s=automotive&ie=UTF8&qid=1450922185&sr=1-1&kCLEANING LEATHER SEATS (IF EQUIPPED)
• Remove dust and loose dirt with a vacuum cleaner.
• Clean spills and stains as quickly as possible.
• For routine cleaning, wipe the surface with a soft, damp cloth.
For more thorough cleaning, wipe the surface with a mild soap and
water solution. In Canada, use Motorcraft® Vinyl Cleaner. Dry the
area with a soft cloth.
• If the leather cannot be completely cleaned using a mild soap and
water solution, the leather may be cleaned using a commercially
available leather cleaning product designed for automotive interiors.
• To check for compatibility, first test any cleaner or stain remover on
an inconspicuous part of the leather.
• Do not use household cleaning products, alcohol solutions, solvents or
cleaners intended for rubber, vinyl and plastics or petroleum-based
leather conditioners. These products may cause premature wearing
or damage to the leather.eywords=sonax+leather+care
  Exclusively recommended by SHOdded.   Also found this on the manuel,and do not puncture any holes on the seats,hope this helps any.  Z
setaonivek
'15 SHO, PP, WPM
