Big shout out to MrHighCaliber for the quick responses...
Here is the finalized order from Tasca for the required washers/gaskets/bolts/nuts for a turbo replacement. If this is for a failed turbo/engine you will also need to replace quite a few more parts. This is for a rip and replace for turbo upgrades.
MrHighCaliber said that MAHLE is also an OEM supplier so the Ford Parts could be MAHLE but otherwise they are listed at OEE.
The only difference in parts between the MAHLE kit and the parts order I placed is that I am also ordering new nuts/bolts in the even there is an issue. This is from TASCA so the parts are OEM.
