Thank you I didn't check back before doing but I'd like to add that the rear left screw is reverse thread I tried for a few minutes the right way notice it didn't even budge tried the other way and it came loose
Here are the photos of the motor.
I had a heater on it the area was very warm w/ also auto started it for 30 minutes not sure if all that dried the water out but it was completely dry just can see the red soap or wax dried on there.
I left the panel off so if I need to replace it or give it a gentle kick to turn it back on it should be much easier.
The motor turned freely.
Sent from my Pixel 4 XL using Tapatalk
You will need a 7mm and 8mm 7 first 3 then 8 for the motor.
