Testing Air Oil seperators
Started by ShoBoat, April 10, 2014, 10:59:52 PM
The clean side separator is an option...,but the can size can't be changed... There is no room for the monster can in any EB except the f150. The ca comes sealed with 2 inlets with check valves and one exit. Not a truly a build it yourself... There is an option for the color.
m3dragon
Was the UPR test done before the kit was made or after? Trying to see the timing for which is best and when.
JLT replied and said only passenger side is what has the oil issue?
I purchased my RX catch can a while back from (BMC) overall great quality piece of art,also have the upgraded hoses and fittings,for now only installed the front clean side seperator,hopefull will kill two birds withy one stone by hopefully installing a meth kit and the catch can by the front bumper,BTW the front clean side will help,but without correcting the lack of evacuation during boost ,it will push alot through the front side,check it every couple of weeks and indeed it does get dirty with oil buildup,pics below.  Z
Heres a diagram that RX was kind enough to send me.  Z
m3dragon
Quote from: ZSHO on August 27, 2015, 07:48:56 AM
Thanks Z, I saw that diagram on this or another thread.
What I am trying to see is if the RX test was done before the new UPR plug and play kit was done. I am trying to figure out between those two. Reading this thread as it is, UPR did not do anything but I can't tell which setup that was.
ShoBoat
I have the rx in my SHO. Happy with it so far. I modded the air supply to vent to atmosphere. Instead of the intake box. I feel that it works better this way.
2012 Pearl White CTS-V Stock
Quote from: ShoBoat on August 27, 2015, 12:04:52 PM
A question if you will... Doesn't this pull unfiltered air consistently into the system?
ShoBoat
Quote from: BiGMaC on August 27, 2015, 06:24:29 PM
No, in my case I have dual filters on the clean side. I'll have to take a pic to illustrate.
ShoBoat
Pics
m3dragon
Is it me or is that airfilter getting oil soaked.
ShoBoat
Quote from: m3dragon on August 28, 2015, 01:52:10 PM
Lol no they are black, there is a white strip on the far side that you can't see that tells you when it's time for a cleaning. You can see it on the other pic.
m3dragon
AH ok. I thought the white was the filter color and black was oil HAHA.
painterpatt
Hey ShoBoat, where is your reservoir located? Tracy at RX installed mine personaly and re checked everything again but I still don't catch anything. My tank is wedged in between fans and motor so now i'm wondering if it is actually getting to hot to cool the vapors down fast enough to catch them.
Koolaid drinkin, Flex drivin !!
ShoBoat
Mine is located by the passenger shock tower. Mine doesn't catch much in summer. More in winter. I do believe that location is a major factor in how well it works.
I would also check and monitor the front clean side oil seperator,sometimes if to much is being pushed through the front side its not a good thing,instead of only focusing how much oil residue has accumulated inside the can.  Z
