Installed H&R Springs-2014PP
Started by 11BLKFX4EB, April 14, 2015, 01:09:06 PM
Quote from: slurppie on March 26, 2016, 10:58:26 PM
Quote from: FoMoCoSHO on March 26, 2016, 09:59:21 PM
@meanks
These guys can build custom springs, I'm serious considering going this route
https://www.eatondetroitspring.com/products/vehicle-types/oe-replacement-springs/
I need to give them a call. Would be nice if they could match the PP's spring rate but produce a spring 1" (+/-) shorter.
sent from my speak n' spell using tin cans and string
1" drop still leaves us too high in the ass end IMHO.
The car with an inch cut off in the rear only looks about perfect rake wise (I prefer a little)
In my mind that would mean 1" in the front and 2" rear.
slurppie
I have an extra set of rear PP springs and looked at cutting them but upon closer inspection the area where you would cut starts to flatten out which makes me think that these aren't the right springs to cut.
2013 w/PP
Synthetic blinker fluid
Ceramic muffler bearings
92BlackGT
the rear springs can definitely be cut. the part that sits in the control arm is where you cut.
http://www.ecoboostperformanceforum.com/index.php/topic,5204.0.html
'14 Taurus SHO - non PP, Unleashed E20 tune, 3 bar - 12.91 @ 106.5 mph
'93 Mustang Coupe - AFR 165's, FTI cam, ported Cobra intake - 13.05 @ 105.6 mph
92BlackGT
@meanks
keep us posted if you do this. it would be great to get another option besides H&R.
m3dragon
Quote from: slurppie on March 27, 2016, 09:32:45 PM
Dam Dam just saw this post. Installed H&Rs over the weekend. Ride is what I expect, very tight and does make the car feel like it should, sporty. I wanted Eibachs but after several calls with them they will not make the springs as low market volume. A slight less drop in front would be preferred and level in the rear is ideal.
Post up if you go that route and what the specs are. For now will enjoy the H&R
