SCT Errors
Started by Scott4957, December 21, 2015, 09:34:20 PM
Deleting directly from the X4?  What error are you getting?  Firmware up to date?
Brucelinc
Quote from: SHOdded on July 17, 2017, 11:16:19 AM
Yes, X4 hooked to computer and updater software open where you can add or delete custom tunes.  There is no error number...just says "failed."   I guess I need to return to stock and try the update?
hawkeye93
I have the same problem, but only with one of my tunes.  The others can be deleted without issue.
2015 Ford Taurus SHO PP 12.219@112.84
PPE catless DP, Gearhead IC, SP-534, Reische 170, 3 bar, hybrid meth system, tunes from Unleashed, Livernois, Brew City Boost & AJP
1965 Ford Mustang Convertible 289 4V/T5Z/3.55
1955 Ford Fairlane Club Sedan 272 4V/Fordomatic
That might work ... not sure why you'd HAVE to return to stock.  What version of Windows are you using?  Windows 10 has been known to throw a curveball now and again.  The updater definitely recognizes the X4 without any issues, right?  How many unlocks do you have left on the X4?  wondering if somehow it is "locked"?
I am sure AJP/FoMoCo/SBS/... will know the answer tho.
Brucelinc
Quote from: SHOdded on July 17, 2017, 06:04:08 PM
My X4 is new and has only been married to my car.  I am still on Windows 8.1 and I have added several tunes over the past week or so and even deleted a couple earlier.  I just added a new tune with no issues and decided to delete those that I knew I wouldn't use but cannot get them deleted from the device.
I returned my car to stock since it is going to the dealer for warranty work.   Before doing that, I did click on the "check for updates" tab on the X4 and got a warning to make sure the car had been returned to stock prior to checking for updates.
Hopefully it was a glitch but glitches on these devices make me nervous, call me a Nervous Nellie, LOL.  The connection between tune files and firmware is a bit screwy.
If the issue continues, you may want to RMA the device, I believe directly thru SCT.  Phone being the best way to contact.
Brucelinc
I returned the car to stock, did a factory reset wiping out all of the tunes that were on the device and reloaded just the ones that I wanted.
I will not likely ever reach the 10 maximum tunes that it holds now.
Aint gonna knock it if it works!
