Quick background, before my SHO, I had a Crown Vic for 16 years and before that I had a '95 Mitsubishi Eclipse GSX that I had installed a manual boost controller, ported intake and aftermarket intake.
So, I'm back to another AWD Turbo!
Back then, oil starvation and coking on the turbos was a big deal so I invested in a pre-lube system that would delay startup until oil pressure had kicked in and then actually keep oil circulating after shut down to cool the turbos.
Ok, enough history. I know the main journals on our turbos are both oil lubricated and have a water jacket so coking is no longer a problem, but what about startup oil starvation? Has anyone installed or considered installing a pre-lube system? The only one I can find now is this
http://www.engineprelube.com/ ?
