14 XSport tire fitment
bigmoneycloser
Have to confirm with my wheel guys. But I thought I would see if anyone here has some info.
I wanna run a 22x10.5 with 285/35/22's up front and in back.  Looks like they will be 11.5 inches wide mounted.
Does anyone know how I could confirm if these will fit front and back without any rubbing or issues?
My other options is the 22x9. But I just think the truck would look mean as he'll with the 10.5's
Thx
Thx
Well, let's do some measurements with what you have now vs. what you want.  Take pics and closely measure any places of concern on your current setup.  With the known offset and width of your current setup, you'll be able to actually see where the 22" options land on the inside and outside.  Then using that, you'll be able to know where the tire will be too.
Another option is to have the company providing you the Vossens do a check in their "red book", which is a somewhat sacred book (or online resource) to provide fitment specs.  They will be slightly conservative, but hey, it worked for my staggered setup so it may work for you.
OR, have the Vossens shipped in but work it out so that you get a guarantee from the wheel shipper that you can return the wheels if they don't fit, or something like that.  I've had a lot of conversations with wheel companies that ended up with, "well, as long as you don't mount a tire to them, you can return them for a full refund" since they were unsure if the wheel would fit, since the Flex isn't a typical car for an aggressive setup...at least not yet <grins>
I'm a little Jelly on the Vossen CVT's.  They weren't out when I placed my order, else I probably would have gone with them.  I would consider swapping with you + some cash on them, that's how much I like that wheel.
