2010 flex a/c pressure switch location
2010Limited
Can anyone tell me where the a/c pressure switch it located? I know it’s behind the front RH bumper but I can’t find that thing. I had it replaced last year and they said it was a nightmare buried back there. The ac stopped working and I’m thinking it’s bad again
Did you happen to check behind the passenger side wheel well liner! Turn the wheel all the way in to gain access to wheel well liner.
Then follow the metal line from receiver Drier to Condensor.
I think you can see the pressure switch from here. Z
ZSHO said:
Did you happen to check behind the passenger side wheel well cover liner! Turn the wheel all the way in in order to gain access wheel well liner. Z
I will take a look. I’m doing hubs today. TIA
NP! Let us know how it goes!
Follow the line from Receiver Drier to Condensor.  Z
Unfortunately you can’t get to it from the side. Underneath is hard but reachable but removing the headlight or the bumper is probably better.
The headlight would be on my next list! Btw make sure to have an extra bulb on hand while removing the headlight assembly! Burned mine that way. Z
F5RZ-13466-C
https://fordpartsgiant.com/parts/ford-bulb_f5rz-13466-c.html?Vin=1FAHP2KT5DG183206&Filter=()
