2013 pp sho front rotor size in mm?
avidmotion
Couple of questions. What is the front rotor size in mm of the 2013 shoo with pp?
What do they mean if I have "painted" front calipers, black or red.....mine was aluminum color.
What is the pad material of the 2013 pp pads?.....ceramic or semi metallic.
Can you mix front ceramics (stock? with ferro carbon, like Hawk HPS?)
I believe the Front Rotors are 13.9"=353.06mm.....2)They simply mean if you painted your calipers black you have the option to order PP Pads with black hardware to match your current black caliper setup...same rule/options apply to the rotors.3)The Motorcraft pads are semi-metallic and IMO would not mix the setup.  Z          Front 13.86"13.9" Dia. rotor..Rear Rotor 13.5"-13.6"= 345mm dia. rotor.  Z
Ok thanks I ordered stock motorcraft pp pads for the rear. I like the PP brakes I will just stay with them. They look just like carbon metallic pads, black and very coarse.
Ok I got the EBC S13 front kit. It has EBC RK Sport plain zinc coated, with the vented hat 13.9 rotors, and  EBC yellowstuff pads. The rotors are beefy 34 lbs.  a piece. They have all kinds of vent holes in the hat. The quality is super nice. Update when on...
