dlepak said:Leadfoot said:Just installed the Motorcraft PP struts and shocks, along with the Power Stop K6375 /Z23 brakes and rotors yesterday. The ride is definitely stiffer than the non PP suspension, almost on the harsh side, although I did have 100K on the old suspension so it's not really apples to apples.
Got rid of the "clunk" with a Mevotech sway bar endlink.
Really like the look of the slotted rotors and they stop well too.
I have 109K on my car. My parts just came in today. I probably will start with the back suspension tomorrow and finish up the fronts next weekend. How was it taking the fronts out and putting the new ones in? Any tips?
There's a write-up someone on the forum but I didn't have a chance to look for it.
The strut mounts are directional, so mark one stud before removing and when you install the new assembly, put it in the same hole. There is also an arrow on the strut mount but the mount may move when taking it out.
The two bolts on the bottom of the strut are splined so they need to be pushed (hammered) out from the front.
You'll need a spring compressor to remove the strut mount. My friend owns a garage so I did it there but you can probably take them to a local shop to swap out the struts.
