2013 Taurus VSHO PP: Rear 3rd Brake Light High Mount Lamp replacement
Peetah75
Hi, Relatively new member of this helpful forum.  I noticed my 3rd brake light is out.  I found one video of a guy replacing his. It looks fairly simple by first removing the cover then unplugging the bulb, with what looks similar to a 9 volt battery only 2 male connectors.  Anyone done this? Is it that easy?  The lamp assembly prices range from about $85 and up for new oem replacement.  Appreciate any advice.  Thanks.
Hi Mac,  just seeing your reply now.  Here is the vid linky:  https://www.youtube.com/watch?v=LksNBY_wvwI
I ended up getting a replacement part from the online ford parts division of my local dealer for $84 and found it was easy to remove the old and replace with the  new one.  It is all about lining up to two connectors correctly, then it snaps back in.
