Got my car dynod at Fathouse Fab, in Martinsville Indiana today. (http://www.fathousefab.com/services/dyno-tuning/)
1st pull looks a bit funny power wise, compared to the next two, but it was most heatsoaked. 2nd and third pull are pretty close to each other, the first 3 are power pulls.
The last pull, is run with the "stock" tune from AJPTurbo. It had the fuel optimized for my E20 blend, stock BOV DTCs removed, rear O2s disabled/modified for catless downpipes. Also has the fan settings for the 170 thermostat. NO spark or boost modifications. Hows that +100 torque gain?
Average from the two (SAE corrected): 369.4/451.4
Other correction factor numbers were a bit higher, but I like the SAE system.
I can NOT stop smiling, I love it.
Results below, as well as logs.
Wastegate mod was open the full pull (the Dyno appears to put more load on the car) so it could have benefited a bit from a stronger spring pressure. However, it will stay with the current 14.5 wastegate spring, until I get a track time to match, then I may play with it. Of course, at that point, it will be warmer so there will be more margin in the fuel system.
This is STD Correction, you can see the average is a bit higher, 377.5/461.3
Either way you look it, car puts more power down, TO THE WHEELS, than ford claims stock at the flywheel. That is SIGNIFICANT improvement in my book. And the torque at the wheels, is over 100 ft/lb greater than the stock torque at the flywheel.
That is an INSANE gain IMO.
Also, here is the exhaust during the pull
https://www.youtube.com/watch?v=WQlkF54XZ-E
