Hi everyone,
Nothing groundbreaking here but worth sharing; I've decided to add a sub to my SHO, I've done a stereo in every vehicle I've had, but this is the first off the stock headunit. I wanted to make sure I got a good signal to the amp so I went with a Lc2i LOC/line driver. A friend of mine has had good success using one in his 2014 Ram, Compared to the basic PAC LOC he whas using before the Lc2i blows it away.
I'll be using a alpine PDX 1000.1 that looks like it'll be small enough to stealth install behind the trunk lining near the factory amplifier, kinda on the corner between the strut mount and upper rear deck. The Lc2i is going to be mounted directly beside the factory amp, utilizing two of the factory studs that mount the factory amps mounting plate.
The Sub is a Eclipse Titanium 12" (quite the beast) The box is not quite as good as it could be as its a MTX prefab box. It is 3/4" mdf @1.75 m3 with a decent slot port volume; not sure what the tuning is on the port but its really a decent box for the $40 I paid.
I went with running the 4awg cable through the shift cable grommet (beside gas pedal) and along the center console to the back of the car. The Lc2i just needs bass signal right now so I'm using the Purple and Yellow (As far as I can tell this is correct, confirmation would give some piece of mind) wires off the Sony amp to the Lc2i. I'll probably end up adding the other woofer channel to the Lc2i to get the best signal.
Hope to get this finished up today!
