So I am embarking on another journey with my Taurus. I am replacing the rear deck subwoofers with a little JL action. My plan is to add a small amplifier tucked away on the rear deck to drive the new rear subs I'm putting in place of the 6x9s. With that being stated, I looked at the wiring diagram and I can't figure out the following:
#1 Where are people pulling the remote wire from? What pin on the processing module?
#2 are you recommending that I pull power from the front of the car? I The amplifier I'm using is the alpine KTP-445u which has a 16GA power cable cable to power it. Can I tap into the processing module for this and the ground as well?
I got two JL 6.5" Subwoofers that are 4 ohm with the 6x9 adapters. The factory system is 2 ohm, which is why I need to do a 4 ohm setup. I need to drive a little more power to these speakers, so the 45wx4 is a perfect amp to do so. Plus, I'm only using 2 channels which is driving the power upward for these rear deck speakers.....
Thoughts?
Thoughts?
