I should be putting this on on Thurs when I have a limited time access to a lift, is there any shortcuts, or tips anyone found helpful for putting it on theirs. It is a 2011if that helps. Thanks in advance!
It should bolt bolt right on and use stock hangers. Make sure everything is straight and mufflers are level (tips through the rear valance straight) before you tighten it all up. Good Luck!
