ElvenSho said:
Would e15 give me benefits over 93 with no ethanol? The reason i ask is because i dont have to mix e15 or e25 because the pump i go to has it already. If.i have to mix each time i get gas id rather just stick with 93. I guess i can use e25 for a while and once it warms up a bit i will send torrie a log so he can tell me whats up.
E-0 lets you run 2 more gallons than I can and still be at where I am which is actually about E22 which would put you at 96.2 octane where I'm at 95.
Ethanol has a much higher
effective octane when direct injected so I guess I'd say you could go the non mixing route but it won't be optimal for either octane number.
Is E-85 available at the same station as the E-0?
Finding E-0 in this country is almost as hard as spotting a purple unicorn these days.
http://www.intercepteft.com/calc.html
