Anyone know how to swap a fuel injector on these?
MikeB
Anyone know how yet? From what I can tell I need to at least pull the intake off to gain access to the fuel rails. Then I'm assuming I need to pull the valve cover off?
Looking at that pic I don't think that the valve cover needs to be pulled. The rails are in the center of the intake and the injectos have to enter at the side of the head next to the intake port. I guess I'll find out LOL.
According to the factory service manual, the valve covers do not need to be removed.
-Rod
Thanks. It actually doesn't look too bad. I'll see if I can get an injector and intake gasket and swap the injector this weekend.
Alright, I was able to knock it out last night. Not too horrible of a job. You do have to drain the radiator and disconnect the upper radiator hoses, heater hoses, and turbo coolant hoses from the intake. You have to remove the upper portion of the air box and the first part of the intake tube. You also have to remove the rear turbo outlet pipe. Once all the connectors are all unplugged from the intake you can unbolt it. You also have to disconnect the fuel line that goes to the hpfp. Removal and install of the intake is a 2 person job because someone needs to help pull the harness out of the way. Getting the fuel rails out is a little tricky cause they're in there tight. You may have to cut off a couple zip ties that hold the harness to the rails because you need the clearance. The injectors go out and in like any other.
I cleaned them all up and replaced the bad one. The injectors had some deposits as well as the back of the valves. Nothing a can of seafoam won't fix. I got it back together and it runs perfect now.
Oh, I forgot one thing. The fuel pump will turn on for a moment about every hour or so even when the car is off, so make sure to put a can under it to catch the fuel when it does that.  :bangin:
Great information, thank you for the details and the tip on the fuel pump running.  Finally there seems to be merit to the manuals having step 1 typically state to disconnect the battery.  I almost never did that in the past, but it seems like a good habit to get in to these days.
-Rod
