Corsa install tips?
PokerMunkee
Finally got my garage back (MIL's stuff is moved out finally!!) and now looking at installing my Corsa exhaust finally.
I've driven up the ramps both ways and there isn't much clearance on each end.
What's the best way to put the car up in the air in a garage w/ no lift to install this thing?
What tools do you have? I would personally jack one side up by front passenger door and rear door with parking brake applied and proceed from there.
Your going to have four bolts connecting to the DP'S,spray some pb blaster so you can loosen then up more easily,would inspect the two gaskets,but would prefer to install new ones and the rest should be hangers,mine were cut in two sections,first cut right before the mufflers,but leaving about  foot of piping for future use,then cut right after the 3rd cat,cause the whole system weighs about 100lbs.
