Creaking sound on 2013 SHO
Timeless
Just checking to see if any other fellow SHO owners have experienced a creaking sound from the front of the car.  Mine seems most audible when making a slow left turn into a parking spot like situation.  It is loud enough a co worker could hear it outside as I was pulling up.  Also can hear some vibration like sound inside the car during normal cruising that I think is related to it as it just started also.
Just checking before I take it in.
Thanks!
Yes.
I have these issues -- there is a TSB on the half shafts for our front end. Ford is ordering replacement parts and the car goes in next week to get fixed up.
TSB 13-5-14; TING/POP/CLICK NOISE--FRONT HALFSHAFT
I had the same issue with my 2010. The dealer installed a new driver side axle shaft. Under warranty. The sound is gone. But sometimes I feel like  hearing the same sound, or something like it, while turning. It's not nearly as noticeable. Maybe in being paranoid. Do you know of any TSB's for 2010 models about this issue?
While I did have some noises on my front left suspension, it was more of a clunk, at all speeds. They replaced my strut, shock and strut mount. Sounds (or doesn't sound) fine now.
