Does your EB smoke at idle?
ShoBoat
Maybe this is the cause, he is running catless dp btw. He also listed a fix in his other vid.
http://youtu.be/G2aD-_LObEk
Interesting, the owner said that a catch can or rising the idle to 1k rpm would solve the issue, with catch can being a proper fix, and the idle as a bandaid.
BiGMaC said:
Dxlnt1 said:
PCV  valve!
Intake valves
Educate me please... Why would lowering the vacuum (or maybe it was the load of the AC and not the vacuum per se) stopping the smoke?
My 2 cent education says it Its not the load itself but removing all the crankcase vapors. Should not require that much vacuum to clear crankcase. Maybe check for oil smell or water vapor in smoke. There are other things that could contribute but those are MAJOR items. Rings, heads, manifolds.
In older cars, the PCV valves were a weak link in so many issues including smoking. That being said "could" also point to valves not seating properly in closed position. And/or cam worn down. Maybe crap on valve seats.
This all based on my knowledge of older cars that had smoking issues. PCV valves cheap plastic. Even catch can. So…...
Catless DPs will of course not "hide" a problem, catted DPs will, to some extent.  Are they excessively wide?  Is the brand being used a reputable one?  Plus I am sure there are unnamed mods on the Mustang, because the mods are not clearly stated in writing on the post.
Downpipes
Catbacks
Intake systems
Different engine oil
Tunes
Spark Plugs not gapped properly
The list goes on & on ...
I can see how increasing crankcase vacuum will help. It is listed under many turbo manufactures that the crankcase pressure can cause smoking by allowing oil to get past the seal in the turbo. So a good catch can set up may help. That said what would just a check valve do?
ALL -- I had this exact issue with my Stainless works catless DPs. Honestly, its nothing "serious" its just how our engines operate. I am +1 for the catch can.
