Down Pipes
Skydogs
The big question what off road down pipes are the best fit and finish?  Need to order asap!!
Thank you Skydog
I loved my stainless works pipes, went on without issue. However, they originally did have an issue with one O2 sensor placement. Mine were bought used off of AJP Turbo, and he had sent them back to SW for correction, and to fix a crack that they got (they had some issues in early production).
I did not want to wait for the PPE pipes so I have some S.W. on the way!! I will post pics of install at my shop very very soon!!
Thank you guys!!  P.S. Thanks for the pics!!
The ones you got from me were actually a brand new pair that Stainless works made for me at their facility. They didn't repair the ones I had that cracked. They used my car to modify their patterns for provisions for PP SHO's with oiler cooler for correct 02 sensor placement.
Any issues with emissions testing with these?
Codes with stock tune?
They're local to me, so this might be an ideal situation
Gray Brick said:
Did the wrap lower the sound level in the car?
I also have SW Exhaust, So as loud as it is..I do not think so,
BUT that is not why we wrapped EM, The Idea Being remove the heat,
And i think that was worth the Small amount of money and effort... :)
YES Code issues, but they go away when you tune it, or get it tuned...AND
Off road means off road, SO A BIG NO to the emissions Question, and
i thought there was trouble with the Cat Version as well (posted here somewhere)...?
Aftermarket Cats (hi-flow) are not necessarily as efficient as stock. As such, they do not always allow emissions readiness checks to set, and the car still may not pass emissions testing. ANY change to emissions equipment is against federal regulations, and you can get in trouble, if it is noticed...whether you go from stock to catted aftermarket, or stock to offroad. PPE catted pipes are said to pass emissions tests, but I never ran them since I don't have emissions anywhere near me. SW pipes, even catted, likely wont be able to set readiness. You have to pay to play, so they say.
Skydogs said:
SHOdded said:
No longer looks like an anaconda trying to swallow a human.
Lmao yeah right wow those o.e. pipes are bad....
All the flat spots, and the HORRIBLE O2 sensor placement that makes it almost impossible to get the one pipe out without damaging an O2 sensor during sensor removal or smacking it with a wrench/ratchet while removing the pipe. The SW sensor placement vs. downpipe mounting bolts is so so so so so much better IMO.
Question on wrapping,
If I get catted downpipes, do I wrap cat as well?
For your guys who posted pictures here, how is wrap holding up year later?
Thanks
Thanks
Absolutely!  They get extremely hot. I posted two pics.  First one are my PPE's wrapped, second is after about a 1000k miles and you can see the black wrap is turning white because of the heat.
That's why I am asking about cats themselves, I know cats do get very very hot, tape holding up its one thing, I would like to see some feedback after year of use,
Second question is can them become too hot inside and maybe fry CO2 sensors of even brake down from overheating?
Anyone with year or move of use can chime in?
and also what heat tape did you use, I know some better than others...
Thank you all
