I am not seeing anywhere there are two on each side? i thought there was only one per side, but I could be mistaken.
As far as replacing the driver's side actuator:
Temperature Blend Door Actuator — LH
Item Part Number Description
1 W701696 LH temperature blend door actuator screw (2 required)
2 — LH temperature blend door actuator electrical connector (part of 14401)
3 19E616 LH temperature blend door actuator
Removal and Installation
NOTE: The LH temperature blend door actuator can be accessed from below the LH side of the instrument panel.
- Remove the 2 LH temperature blend door actuator screws.
- Disconnect the LH temperature blend door actuator electrical connector.
- Remove the LH temperature blend door actuator.
- To install, reverse the removal procedure.
- NOTE: The purpose of the module actuator position calibration is to allow the HVAC module to reinitialize and calibrate the actuator stop points. To carry out calibration, carry out the following steps.
Remove Smart Junction Box (SJB) fuse 15 for at least one minute.
- NOTE: When the ignition switch is switched to the ON position, the HVAC module will initialize and calibrate the actuators. Calibration of the actuators will take approximately 30 seconds.
Reinstall SJB fuse 15. Turn the ignition switch to the ON position and wait 30 seconds before verifying correct LH temperature blend door operation.
Maybe you were thinking of the airflow and air inlet actuators:
Temperature Blend Door Position
The dual-zone EATC system uses 2 temperature blend door actuators to control 2 separate temperature blend doors. The temperature blend doors independently vary the LH side and RH side temperature settings, as desired. The temperature blend door actuators each contain a reversible electric motor and a potentiometer. The potentiometer circuit consists of a 5-volt reference signal connected to one end of a variable resistor, and a signal ground connected to the other. A signal circuit is connected to a contact wiper, which is driven along the variable resistor by the actuator shaft. The signal to the HVAC module from the contact wiper indicates the position of the temperature blend door. The HVAC module powers the actuator motors to move the temperature blend doors to the desired positions. The desired temperature blend door positions are calculated by the HVAC module based on the set temperature, in-vehicle temperature, ambient temperature and sunload.
The LH temperature blend door actuator is located on the heater core and evaporator core housing near the accelerator pedal. The RH temperature blend door actuator is located on the heater core and evaporator core housing to the left of the glove compartment.
Airflow Mode Door Position
The airflow mode door actuator uses a cam and lever assembly to position the airflow mode doors on command from the HVAC module. The mode door actuator contains a reversible electric motor and potentiometer. The potentiometer allows the HVAC module to monitor the position of the airflow mode doors. The potentiometer circuit consists of a 5-volt reference signal connected to one end of a variable resistor, and a signal ground connected to the other. A signal circuit is connected to a contact wiper, which is driven along the variable resistor by the actuator shaft. The signal to the HVAC module from the contact wiper indicates the position of the airflow mode doors. The HVAC module powers the actuator motor to move the airflow mode doors to the desired position. The HVAC module determines the desired airflow mode door position based on the calculated outlet temperature.
The airflow (defrost/panel/floor) mode door actuator is located on the heater core and evaporator core housing to the right of the steering column.
Air Inlet Mode Door Position
The air inlet mode door actuator moves the air inlet door between the fresh and RECIRC positions on command from the HVAC module. The airflow mode door actuator contains a reversible electric motor and potentiometer. The potentiometer allows the HVAC module to monitor the position of the air inlet mode door. The potentiometer circuit consists of a 5-volt reference signal connected to one end of a variable resistor, and a signal ground connected to the other. A signal circuit is connected to a contact wiper, which is driven along the variable resistor by the actuator shaft. The signal to the HVAC module from the contact wiper indicates the position of the air inlet mode door. The HVAC module powers the actuator motor to move the air inlet mode door to the desired position. The HVAC module determines the desired air inlet mode door position based on the calculated outlet temperature.
The air inlet mode door actuator is located on the air inlet duct and can be accessed through the glove compartment opening with the glove compartment lowered.
