jimmyducati
So my 10' SHO is still stumbling and missing at virtually all RPM's and engine loads. Its drivable, but in no way acceptable. I have loaded the stock tune back in, cleared all the DTC's, reloaded the 4+, replaced and gapped the plugs, inspected the knock sensor wiring and wrapped it where it passes over the edge of the engine block. The oil is always changed, the air filter is new, tires aired up, tank is full of 93....
I just pulled the DTC codes this morning and the only one that came up was U2107. I can't find this code anywhere online that applies to the SHO, or even a ford for that matter!
Does anyone know what the code is, or what the hell is wrong with this car!!
