I'm at 8 gallons and 43%.Larrylu said:What kind of numbers would you expect to get if you only added a couple of gallons of E85 to a fill up on E10 / 93 octane?
So you have 1.9 to start plus 2 more which should put you around 20ish percent.
20 ish % Gotcha! Sounds real interesting. What would be a good guesstimate for the octane equivalent of that mix?FoMoCoSHO said:I'm at 8 gallons and 43%.Larrylu said:What kind of numbers would you expect to get if you only added a couple of gallons of E85 to a fill up on E10 / 93 octane?
There is more than one way to skin a cat.kinder said:There are several portable octane testing instruments available out there. last I heard they were about $7-1000.
Just saying that if you are gonna play the mixing fuel game with your car maybe it is a worthy investment?
http://www.shatox.com/index.html
http://www.zeltex.com/portable/zx-101c.html
I ran it through the calculator found here...Larrylu said:20 ish % Gotcha! Sounds real interesting. What would be a good guesstimate for the octane equivalent of that mix?FoMoCoSHO said:I'm at 8 gallons and 43%.Larrylu said:What kind of numbers would you expect to get if you only added a couple of gallons of E85 to a fill up on E10 / 93 octane?
That would be a roughly 30 percent mix right off the bat. It will take some time for the car to trim that out....so no.SHOnUup said:So I've been avoiding (phone put "the tax penalties" for next word options right there...lol) reading this thread as I'm still learning alot about our SHO. Thinking about heading to Milan today for test and tune now that the 3 bar tune is running. Do you guru's think a few gallons into a half tank would help me out a bit at the track today. Maybe I should go without mix this time and test against next time?
Maybe but the bigger problem I just realized is you have a 2011. Everyone says e-85 is like kryptonite on gen 4.1 and all my experiences are on 4.2 with the updated LPFP. So my advice is slow and steady, starting at 2 gallons and seeing what happens......slowly.SHOnUup said:40 miles to track?
