Ecoboost basic swap info
lamrith
I am wondering if there is a way we can get some information compiled in one place and make it a Sticky?
I do not have the answers to any of this, but was just debating a possible swap and realized this was critical information needed to make a decision that would make for a good sticky thread here in the Swap area.
If I missed one or have any of them wrong below let me know, I will update the OP as I get information.  Also if there is additional info
CAR/SUV AWD 3.5ECO (Transverse mount):
  • Engine Type: Transverse Mounted twin turbo V6
  • Length In(mm):
  • Height In(mm):
  • Width at heads  In(mm): 22" (559)
  • Width at widest with fact. turbo  In(mm):
  • Width at oil pan  In(mm):
  • Weight lbs (kg):449(203)
  • RPM Range:
  • Bellhousing pattern:
  • Factory trans options:
  • Factory HP: 365 @ 5500rpm
  • Factory Tq (lb/ft): 350 @ 1500-5000rpm
CAR 2.0ECO (Longetudenal mount):
  • Engine Type: I4
  • Length In(mm):
  • Height In(mm):
  • Weight lbs (kg):328 (149
  • RPM Range:
  • Factory HP: 240@5500rpm
  • Factory Tq (lb/ft): 270 @ 1900-3500rpm
CAR 2.7ECO (Longetudenal mount):
  • Engine Type: V6
  • Length In(mm):
  • Height In(mm):
  • Weight lbs (kg):440 (200)
  • RPM Range:
  • Factory HP: 315 @ 4750rpm
  • Factory Tq (lb/ft): 350+ @ 2750rpm
TRUCK 3.5ECO (Longetudenal mount) dimensions/specs:
  • Engine Type: Longetudenal mounted Twin Turbo V6
  • Length In(mm):
  • Height In(mm):
  • Width at widest with fact. turbo In(mm):  28.5 (724)
  • RPM Range:
  • Factory HP: 365 @ 5000rpm
  • Factory Tq (lb/ft): 420 @ 2500rpm
Few updated from a wiki I found.  Still no detailed measurement info though which for a conversion is the most important aspect.
https://en.wikipedia.org/wiki/Ford_EcoBoost_engine#3.5_L
