Engine/Transmission Mounts
dubcitySHO
Are there any aftermarket mounts available for the transverse 3.5EB?  I haven't been able to find any.
Seeing how far our engines flex during dyno sessions show progress could be made with a more solid constuction mount or higher durometer bushing.
Some of the hockey puck style mounts can be filled with 3M window weld
https://m.youtube.com/watch?v=UtBfMwb4034
I did this on my 2014 Nismo Juke RS.
Cut the excess Rubber out. Brake Clean it. Duct tape on the underside of the Mount. Kitty litter in a box. Pour in the Urethane. Monitor the level of the Urethane and top off / adjust the levelness of the mount in the kitty litter. It takes a while for it to cure so dont just pour and forget about it.
The lower pic is the duct tape side after curing.
SHOdded said:
But ... But ... did it work?  What was the difference ...
My last 2 vehicles before the SHO, I had aftermarket mounts in, and it held the engine and transmission more stable, but the flip side I got a lot more vibration through the chassis.  They were both manual transmission cars. I don't know if an automatic would change that outcome at all.  I don't see why it would, the energy has to go somewhere though.
It worked on my Juke. Made the car drive better. Handle better. Respond to throttle input faster. Trade off as mentioned above is more cabin noise.
I cannot say what this will do to a SHO as the mounts are in different locations and are different design. I was just offering a different way to do them that works really well.
Buy a used or new set of mounts. Mod/Urethane them. Then you can swap them out for Long trips, Servicing, etc with the unmodded mounts.
Finally had a chance to Dyno tune my Juke with Modded engine mounts.
I think this would be a worth while mod for the guys trying to get their 60' times better. It might eliminate some of the wheel hop as well. It eliminates it all in the Juke but that is a 6 speed manual and a totally different platform.
https://youtu.be/Fw8N-8eDssY
