05yellowgt said:
You did it!!!! Can you imagine this motor in a lightweight Mustang! Is there any way to limit boost in lower gears? I have a feeling lauching is going to be interesting!!! Any street driving impressions, or even vids??
Haven't driven it on the street at these HP levels yet, I leave today for Vegas for 4 days and when we get back we'll do some more work/tuning/dynos and some street videos.
thatsmrgimp2u said:
Have you seen what your hpfp pressures are at?
Sent from my DROID RAZR HD using Tapatalk 4
HPFP is at 2100psi at wot this is due to my aux fueling system supplementing it.
First-SHO said:
Mike, are you still running stock pistons and rods? You are sure pushing the drive train limits, but it is awesome seeing what this engine is capable of.
YES!
The motor is STOCK internals.
The car has the following mods:
Dual in tank fuel pumps
6 auxiliary injectors
Split-Sec aux injector controller
Car runs on straight E85 - 23 degrees of timing.
PPE Engineering 2.5" catted downpipes with stock cat-back and sound performance racing cutout.
Custom turbo to intercooler and intercooler to throttle body piping with silicone tubes to replace factory plastic/rubber parts. Replaced factory electric BoV with Tial BoV.
First night
First pull 505HP/515TQ 15PSI - using stock ECU for boost control
Second pull 563HP/598TQ 23PSI - removed connection to factory boost controller, turbos running on wastegate spring
Next night
Third pull 587HP/642TQ 25PSI - same as second pull - allowed the boost activated cutout to open
Fourth pull 592HP/630TQ 25PSI - same as third pull - disconnected piping to filter in the fender
Fifth pull - not on video 600HP/642TQ - Cutout open, car had sat as we were uploading files to ECU - car was running cold air intake
We haven't tuned the car yet, this is a tune from Torrie at Unleashed from months ago on my old compressor wheel upgraded turbos with E85. We're just adding fuel via aux controller.
