avidmotion
Great article ...Ford brand pdf...
Hybrid police vehicles...
n addition, police-programmed AdvanceTrac® Electronic
Stability Control provides the confidence to hit corners hard.1
The system constantly monitors wheel speeds, steering angle, lateral
acceleration, and vehicle rotation for both the vertical yaw axis and
horizontal roll axis. To help avoid skidding and fishtailing, it utilizes
the Anti-Lock Brake System (ABS) and traction control whenever
wheelslip, understeer, oversteer or roll motion is detected. Roll Stability
Control™ has gyroscopic sensors that check body-roll angle at least
100 times per second.
Designed exclusively for police operations, the all-new Police
Interceptor has 3 all-new high-powered powertrains to optimize.
The standard 3.3L V6 Hybrid propels at a 318 combined system net
horsepower and 322 lb.-ft. of combined system net torque. Generating
an even more formidable 400 hp,2 the available all-new twin-turbo,
direct-injection 3.0L EcoBoost® V6 also delivers a powerful 415 lb.-ft.2
flat torque curve across the rev range. Output for the optional all-new
flex-fuel 3.3L V6 is a robust 285 horses. Naturally aspirated V6 muscle
employs twin independent variable camshaft timing (Ti-VCT) to help
achieve peak power or efficiency, as conditions warrant.
