These cars have a different sensor, I'm senile so I forget but it's a driveshaft rotation sensor that could be turned into mph or simulate abs I'm sure.breeves002 said:I'm going to do some more thinking and post back here.
Install a cable driven throttleKidding of course.
Maybe find a way to instead of replicating the ABS data, simulating it. You'd need to have a computer that could basically tell the ABS computer that all wheels are rotating at the same speed (which should be the speed your VSS shows).
These cars have a VSS, right? Or is it through the ABS sensors. If thats the case this may not work. It's a long shot, but just brainstorming ideas.
