explorergotoluvit
has anyone put gauges in there explorer? if so pictures?
SHOnUup said:I've seen pics of someone's setup that mounted 2 gauges to the steering column, can't find them to share though.
Rich
mval said:tom:
the more that i looked at the obd gauges the less i liked the plx, that's why i went to the cheap on my chall. to me if i had the expertise i'd run what larry & another couple guys on here are running, the wireless connect to a nexus running torque. i flat out love the way larry's looks & the info he gets from it like kr is just impressive.
mval said:tom:
nothing wrong with your idea at all. the only problem is your limited to what the obd monitors & can you split obd to mutiple gauges.. I don't know about the sho, but the chally doesn't monitor oil pressure. wideband afr, or egt. now all those require hitting the engine somewhere to get the readings, so are more expensive to install. i really like the wideband afr as it immediately tells me if air/fuel mixture is right. egt I like as it measures engine temp. on my obd it's got some info like air input temp/ coolant temp, boost, things like fuel trim by bank. load rating , torque. my chally actually has a setting to show oil pressure the only problem in that mode can't surf the sirius stations, i like my toons a lot. really like the way todd did his aeroforce off the column. if money was no object would do the wideband afr, egt & an aeroforce in chris pod & another aeroforce like todd did his. but the thing i don't know is if you can split the obd to multiple devices, this is what the plx was doing, but saw a couple bad reviews & just to many boxes to make it work. choices/choices just stay away from prosport evos. like i said dynamite gauge at night time.
