TracKey and Track Cal are Ford Racing exclusive calibrations that provide added functionality to 2013-2014 Mustang GT's with manual transmission. TracKey is also available for 2012-13 Boss 302 owners part number M-14204-MBTKA
Both calibrations include these exclusive features:
- Driver adjustable Launch Control, or "2-step engine speed limiting"
- Driver adjustable Pit Lane Speed Control
- Lopey idle
- Improved engine performance- Up to 60lb-ft at 1500rpm & peak increases of 16 hp and 7 lb-ft on 93 octane fuel
TracKey or Track Cal - Which is right for me?
TracKey provides the customer a unique key that activates the calibration once it has been installed. TracKey is sold and installed exclusively through US and Canadian Ford and Lincoln Dealers. Special equipment and training is required to install TracKey.
TracKey is available for 2014 Mustang GT (manual transmission only) built after 7/1/2013. The vehicle build month and year are located on the Mfg. by Ford Motor Company decal located on the driver side door jam.
Track Cal is supplied via our exclusive Pro-Cal flash tool. It is always active but lopey idle can be turned off. Available for all 2013-2014 Mustang GT's with manual transmission.
How do TracKey and Track Cal work?
TracKey and Track Cal both contain exclusive calibration features designed for track use and derived from the same software algorithms and features employed in Ford Racing turn-key race cars such as the Boss 302R, Boss 302S, and Cobra Jet.
Engine performance is similar to the calibration available in the Ford Racing M-FR1-MGTB kit and modifies several PCM parameters including:
- Twin Independent Variable Cam Timing (TiVCT)
- Engine braking
- Ignition timing
- Wide-Open Throttle fueling
- Accelerator pedal map
- Idle speed
- Throttle response
TracKey and Track Cal for Mustang GT
- Alter several thousand lines of code and several hundred calibration parameters.
- Are the only calibrations of their type that have gone through the rigorous Ford Racing test procedures.
- Are a 50 state legal aftermarket engine performance software upgrade for the 2013-2014 Mustang GT with Manual Transmission (TracKey only available on 2014MY build date after 7/1/2013 date
NOTE:
Federal and state laws prohibit any person from installing aftermarket add-on or modified parts prior to the sale of a new motor vehicle
