I bought a 170 degree T-Stat for my 2014 Sport.
Does anyone have pics of their T-Stat install on their 2013 or 2014 Sport?
I am not sure about where it goes, though I believe it is somewhere "under" the air intake.
Do you drain the system at the bottom of the radiator first or just into a bowl under the t-stat housing?
How did you "Burp" the system after your install.
I've seen the threads on the Flex.....not sure its the same process or configuration.
Your help will be appreciated
